V5 Controller - V5 Clawbot - Claw Control
Step 1: Power on your V5 Controller
  • Press the square Power Button in the center of the controller to turn it on.
Step 2: Set up Driver Control
  • Use the Arrow buttons to highlight the Driver Control program's icon (highlighted in the image).
  • Then press the A button to choose Drive.
  • Press the A button again to choose Run.
  • Press the B button to return to the previous menu, if needed.
Step 3:  Use the L1 and L2 Buttons on the Left Side of the Controller to close and open the claw
  • The rectangular L1 button on the front of the controller closes the claw.
  • The rectangular L2 button on the front of the controller opens the claw.
