V5 Controller - Arcade Drive
Step 1: Power on your V5 Controller
  • Press the square Power Button in the center of the controller to turn it on.
Step 2: Set up Driver Control
  • Use the Arrow buttons to highlight the Driver Control program's icon (highlighted in the image).
  • Then press the A button to choose Drive.
  • Press the A button again to choose Run.
  • Press the B button to return to the previous menu, if needed.
Step 3:  Use the Joysticks to Operate the Drive Train
  • The joysticks will operate the drive train motors in arcade control.
  • Tilting the joysticks forward will move the V5 Robot forward.
  • Tilting the joysticks backward will move the V5 Robot backward.
  • Tilting the joysticks to the left or right will cause the V5 Robot to make a point turn in the chosen direction.
