V5 Controller - Tank Drive
Step 1: Power on your V5 Controller
  • Press the square Power Button in the center of the controller to turn it on.
Step 2: Set up Driver Control
  • Use the Arrow buttons to highlight the Driver Control program's icon (highlighted in the image).
  • Then press the A button to choose Drive.
  • Press the A button again to choose Run.
  • Press the B button to return to the previous menu, if needed.
Step 3:  Use the Joysticks to Operate the Drive Train
  • To make the robot go forward, push up on both joysticks.
  • To make the robot go backward, push down on both joysticks.
  • To make the robot turn left, push the right stick up and the left stick down.
  • To make the robot turn right, push the left stick up and the right stick down.
