VCS Example Program - VEX C++ - V5 Clawbot - Using the Vision Sensor
This example program shows how to program the V5 Clawbot with VEX C++ to use data from the Vision Sensor. The program has the robot move forward when it detects a green object, turn right when it detects a yellow object, turn left when it detects a red object, or stop when it does not detect an object.
UsingVisionSensor.vex
robot-config.h
using namespace vex; vex::brain Brain; vex::motor LeftMotor (vex::PORT1, vex::gearSetting::ratio18_1, false); vex::motor RightMotor (vex::PORT10, vex::gearSetting:ratio18_1, true); vex::vision VisionSensor (vex::PORT5);
main.cpp
#include "robot-config.h" int main() { while (true) { VisionSensor.takeSnapshot(1); if (VisionSensor.largestObject.exists && VisionSensor.largestObject.width>5) { Brain.Screen.setPenColor(vex::color::white); Brain.Screen.setFillColor(vex::color::green); Brain.Screen.drawRectangle(0,0, 480, 240); Brain.Screen.setCursor(2,6); Brain.Screen.setFont(vex::fontType::mono40); Brain.Screen.print("Forward"); LeftMotor.spin(vex::directionType::fwd); RightMotor.spin(vex::directionType::fwd); } else { VisionSensor.takeSnapshot(2); if (VisionSensor.largestObject.exists && VisionSensor.largestObject.width>5) { Brain.Screen.setPenColor(vex::color::black); Brain.Screen.setFillColor(vex::color::yellow); Brain.Screen.drawRectangle(0,0, 480, 240); Brain.Screen.setCursor(2,6); Brain.Screen.setFont(vex::fontType::mono40); Brain.Screen.print("Right"); LeftMotor.spin(vex::directionType::fwd); RightMotor.spin(vex::directionType::rev); } else { VisionSensor.takeSnapshot(3); if (VisionSensor.largestObject.exists && VisionSensor.largestObject.width>5) { Brain.Screen.setPenColor(vex::color::white); Brain.Screen.setFillColor(vex::color::red); Brain.Screen.drawRectangle(0,0, 480, 240); Brain.Screen.setCursor(2,6); Brain.Screen.setFont(vex::fontType::mono40); Brain.Screen.print("Left"); LeftMotor.spin(vex::directionType::rev); RightMotor.spin(vex::directionType::fwd); } else { LeftMotor.stop(); RightMotor.stop(); Brain.Screen.clearScreen(); } } } task::sleep(100); } }
How it works
This program checks the Vision Sensor data for Signatures 1 through 3, repeatedly. If one of those signatures is detected, the program carries out a series of commands that change the display on the brain and have the robot move forward, turn left or right, or stop (no signature detected).
First, the while (true)
line of code tells the robot to run this code repeatedly as long as the condition is true like a forever loop.
Then, the Vision Sensor takes
its first snapshot
of Signature 1 (1 = green signature).
Then, the program decides (Boolean: 1-true / 0-false) if
the Vision Sensor detects that the largest green object exists
and
that the largest object's width is greater than 5
If both of those conditionals are true (1), then the program:
sets
the brain's screen'spen color
to whitesets
the brain's screen'sfill color
to green- then the brain's screen
draws a rectangle starting at (0,0) that is 480 pixels wide and 240 pixels tall
- then
sets
the brain's screen'scursor at (2,6)
sets
the brain's screen'sfont to mono40
prints "Forward"
- and then the LeftMotor
spins forward
- and the RightMotor
spins forward
If those two conditionals are not both true (0-false ---> else
), the Vision Sensor takes a snapshot
of Signature 2 (2 = yellow signature).
the Vision Sensor detects that the largest yellow object exists
and
sets
to blacksets
to yellow- then the brain's screen
- then
sets
sets
prints "Right"
spins forward
spins reverse
of Signature 3 (3 = red signature).
the Vision Sensor detects that the largest red object exists
and
sets
to whitesets
to red- then the brain's screen
- then
sets
sets
prints "Left"
spins reverse
spins forward
If those two conditionals are not both true (0-false --->else
), the program:
stops
the LeftMotorstops
the RightMotor- and
clears
the brain's screen
Then the program waits 100 milliseconds
and starts the loop again by taking a Snapshot of Signature 1 and continuing.
