How to Use Autocomplete in VEX Coding Studio
Get more with VEXcode
We recommend you transition to our new software. VEXcode has both block-based and text-based options, that work on Chromebooks, iPads, Android tablets, Windows and Macs. Visit code.vex.com for more details on how to download VEXcode.
VEX Coding studio has been discontinued and is no longer available for download. Already downloaded? The program will continue to function but will no longer be supported.
Users who transition to VEXcode can migrate their C++/C++ Pro projects to VEXcode Text by following this article.
Step 1: Open VEX Coding Studio
  • Open or create a VEX C++ or C++ Pro project.
Step 2: Write your program code
  • Start typing your code in the text editor window, and the autocomplete pop-up window will appear.
  • Choose from among the available suggestions using the up and down arrow keys.
NOTE: Use the Ctrl + space keyboard shortcut to show the autocomplete menu at any time.
Step 3: Refer to the Command Reference for more help
