How to Charge the V5 Robot Battery
Step 1: Plug the battery into a power source.
  • The V5 Robot Battery can be charged by first plugging pronged end of the V5 Robot Battery Charger into a power supply socket.
  • Then insert the rounded part of the charger into the battery's round charging port at its base.
Step 2: Watch for the LED indicator lights.
  • Keep the battery charging and you should see green blinking lights increasing in number right to left.
  • Wait until four green lights indicate the battery is fully charged. Fewer green lights indicate only partial charge.
  • Note: A red leftmost light indicates that the battery is not charged or is not supplying power.
