How to Connect the V5 Robot Battery to the V5 Robot Brain
Step 1: Connect the V5 Battery Cable to the V5 Robot Battery.
  • Connect the battery cable's rectangular connector to the base of the battery.
  • Make sure that the clip on the connector is positioned correctly. The picture above is the backside of the battery.
Step 2: Connect the V5 Battery Cable to the V5 Robot Brain.
  • Then connect the other rectangular connector to the brain.
  • Again, make sure that the clip on the connector is positioned correctly.
  • If the brain does not automatically power on, press and hold the Power button until the Home screen is displayed.
