How to Interpret the V5 Battery Lights
Step 1: Interpret the battery indicator lights while charging
- Refer to the image above. There is a description written next to each of the green flashing lights that explains the battery charge stages.
NOTE: As the charge progresses, the number of green flashing lights will increase. When the battery is fully charged, all four lights will be illuminated for a brief time and then turn off. All four green LED lights will flash once every five seconds when the battery is charged while still connected to the charger.
Step 2: Interpret the battery indicator lights when it is discharged
- Press the black, circular battery gauge button to view the charge of battery.
- Refer to the image above. There is a description written next to each of the green flashing lights that explains the battery charge stages when it is discharged.
