How to Import .vex Files and VEXcode Projects in VEXcode V5 Text
Note: Only C++ and C++ Pro .vex files can be imported. Modkit .vex files will not import.
Step 1: Launch VEXcode V5 Text
  • Launch VEXcode V5 Text using the desktop shortcut.
Step 2: Click the Import Button
  • From the File dropdown menu, click on the "Import..." button.
Step 3: Select a File
  • Select the appropriate .vex file or zipped VEXcode V5 text project folder to import, and click open.
Step 4: Name the File
  • Rename the project. By default, the name field will be set to "MyProject1." Once the project has been named, Click the Import button.
