How to Add New Files - VEXcode V5 Text
Step 1: Open a Project
  • To add a file to an existing project, open the project by clicking the Open button in the File dropdown menu.
  • To add a file to a new project, click on the New button in the File dropdown menu, give the project a name, and click the Create button.
Step 2: Add the File
  • Right click on either the “include” or “src” dropdown and select New File.
Step 3: Select File Type
  • Select the type of File to add, give it a name, and click the Create button.
NOTE: A correct extension needs to be typed out at the end of the file name in order to create it. The different extension types are listed in parenthesis next to the file type name.
