How to Change the Backlight Percentage on the V5 Robot Brain
Step 1: Make sure the V5 Robot Brain is on
  • Turn on the V5 Robot Brain by pressing and holding the Home button on the brain.
Step 2: Select the Settings icon
  • Tap on the Settings icon as highlighted by the red rectangle.
Step 3: Select the Backlight setting
  • Tap on the Backlight setting as highlighted by the red rectangle.
  • Continue to tap until you reach your desired setting.
