How to Install or Remove the VEX IQ Robot Battery
Have a Charged VEX IQ Robot Battery
NOTE: Click here for help in charging the Robot Battery.
Install the Robot Battery
  • Slide the Robot Battery into the VEX IQ Robot Brain and listen for a click that indicates the Robot Battery has been inserted correctly and completely.
Remove the Robot Battery
  • Squeeze the latch at the end of the Robot Battery and pull it out of the Brain.
NOTE: Pushing on the Robot Battery from the other end helps in removing it.
NOTE: The Robot Battery should always be removed from the Brain if it is going to be stored for longer than two weeks.
Still need help? Contact Us Contact Us
