How to Charge the VEX IQ Controller Battery
Charging a Controller Battery with a USB Cable
Connect the Controller to a Computer or other USB power source.
  • Connect the microUSB to the Controller’s Charge port and the USB to the computer or other USB power source.
  • Ensure the Controller is turned on.
NOTE: The Controller can also be charged by connecting the USB cable to a USB wall adapter.
NOTE: Charging the Controller with a USB cable is the preferred charging method.
Charging a Controller Battery with a Tether Cable
Step 1: Tether the Controller to the VEX IQ Robot Brain.
  • Connect one end of the Tether Cable to the powered-off Brain with a charged VEX IQ Robot Battery and the other end to the Controller.
  • Listen for the “click” when the Tether Cable is inserted into the Controller and Brain to confirm that the Tether Cable is attached securely.
NOTE: Charging the Controller this way is not the preferred way of charging and will partially deplete the Robot Battery’s charge.
Step 2: Turn on the Brain to begin charging.
  • Click here for more information about turning on the Brain.
See the table below to understanding the Charge/Game Indicator Lights on the Controller:
NOTE: There are three possible colors for the Charge / Game LED: green, red, and gray.
Charge / Game LED Color Status
Solid Green Controller Battery is completely charged
Solid Red Controller Battery charge in progress
Blinking Red Controller Battery fault
Off Not charging
Still need help? Contact Us Contact Us
