How to Change the Size of Blocks in the Programming Area - VEXcode IQ Blocks
You can make the blocks in your programming area larger or smaller to meet your needs.
Use the buttons in the bottom right side of the programming area.
  • Use the + icon to make the blocks larger.
  • Use the - icon to make the blocks smaller.
  • Use the = icon to return the blocks to their original size and center your project’s blocks in the programming area.
