How to Reset the V5 Robot Brain Settings to Default Values
Step 1: Make sure that the V5 Robot Brain is on.
  • Have your V5 Robot Battery charged and connected to the V5 Robot Brain so that you can power it on.
Step 2: Tap the Settings icon.
  • Select the Settings icon by tapping on it to bring up the Settings menu.
Step 3: Tap Reset settings.
  • Choose the option for resetting the settings at the top of the right column.
Step 4: Tap OK on the Confirm screen.
  • Tap OK to restore the default settings when this screen is shown.
    The factory defaults should all be restored.
