How to Save a Project on MacOS
You can save your project in VEXcode IQ Blocks in different ways:
  • Selecting Save in the File menu
  • Downloading a new project
  • Naming a new project
Once the save dialog appears, use the macOS interface to name and save your project to your computer.
Once a project is saved, VEXcode IQ Blocks will automatically save all changes in a project.
Saving a Copy
You can also use the “Save As” option from the File menu to make a copy of a project under a different name or in a different location.
