How to Open a Project on Chromebook
Users can open a project in VEXcode IQ Blocks in different ways:
  • Opening an existing project using “Open” in the File menu
  • Using “Open Recent” in the File menu to select a recent project
  • Opening an example project using “Examples” in the File menu
Opening an Existing Project
Open an existing project by selecting “Open” from the File menu.
Then, use the ChromeOS interface to navigate and open your existing project.
Opening a Recent Project
Open the list of recent projects from the File menu.
Then, select a recent project to open it.
Opening an Example
Open the example project chooser from the File menu.
Then, select an example project to open it.
Note: When opening a project, a prompt will appear asking to save if the current project has not been saved yet.
