How to Install VEXcode IQ Blocks for Windows
Step 1: Select the VEXcode IQ Blocks Installer icon to launch the InstallShield Wizard.
Note: You might have to grant permission for the app to make changes to your computer.
Step 2: In the first InstallShield Wizard prompt, select the "Next >" button.
Step 3: Read through the End User License Agreement and select the bubble next to "I accept the terms in the license agreement." Then select the “Next >” button.
Step 4: Select the "Install" button.
Step 5: Select the "Finish" button to finish installing VEXcode IQ Blocks to close the InstallShield Wizard.
Step 6: Launch VEXcode IQ Blocks using the desktop shortcut.
Step 7: Begin working in VEXcode IQ Blocks.
Create a new project to get started with coding in VEXcode IQ Blocks!
