How to Change the Start Screen on the V5 Robot Brain
Step 1: Make sure the V5 Robot Brain is on
  • Turn on the V5 Robot Brain by pressing and holding the Home button on the brain.
Step 2: Select the Settings icon
  • Tap on the Settings icon highlighted in the red rectangle in the image above.
Step 3: Select Start at
  • Tap on the Start at setting highlighted in the red rectangle in the image above.
  • Select the desired start screen.
