Login to STEM Labs Teacher’s Portal Using a VEX Account
A single VEX Account can be used to login to the STEM Labs Teachers Portal.
Step 1: Go to the VEX STEM Labs page at https://education.vex.com/ and click the “Teacher Portal” button.
  • This will redirect you to the VEX Robotics Account Login page.
You can choose to use your VEX Account by clicking on the “Teacher’s Portal” button.
This is the same button for both VEX EDR and VEX IQ.
Step 2: Login to your account using your username and password.
Step 3: Authorize VEX to access your account.
  • You may get this pop up the first time you access either the teacher portal. Click “Authorize” to continue.
Step 4: Start exploring the educational materials and opportunities offered by VEX!
