How to Run the Drive Program through the V5 Robot Brain
Step 1: Make sure the V5 Robot Brain is on
  • Have your V5 Robot Battery charged and connected to the V5 Robot Brain so you can power it on.
Step 2: Tap the Drive icon.
  • Select the Drive icon by tapping on it to bring up the Drive screen.
Step 3: Tap the Run icon.
  • Tap the Run icon to start the program.
Step 4: Control the program from the Drive screen.
  • You can tap Stop to stop the program, monitor the running time, or tap the Devices icon to see the connected ports and readings.
