How to install on a Chromebook - VEXcode V5 Blocks
Step 1: Use this link to open the VEXcode V5 Blocks Chrome Web Store page and select "Add to Chrome."
Step 2: Select “Add app” to give VEXcode V5 Blocks access to your Chromebook.
Note: You will likely see a small popup while the application is downloaded to your Chromebook.
Step 3: Select “Launch app” to start VEXcode V5 Blocks after the download is complete.
Note: You can also find the application in your Application Library and open it from there next time.
Step 4: Begin working in VEXcode V5 Blocks.
Create a new project to get started with coding in VEXcode V5 Blocks!
- Name and save your project (macOS, Windows, Chromebook).
- Configure your motors, drivetrain (with or without the Gyro Sensor), 3-Wire Devices, and controller.
- For help in understanding the blocks, access the Help feature.
