How to install VEXcode V5 Blocks for macOS
Step 1: Launch the VEXcode V5 Blocks installer package and select the VEXcode V5 Blocks.dmg file.
Step 2: Launch the VEXcode V5 Blocks installer and select the VEXcode V5 Blocks.pkg icon.
Step 3: Continue past the introduction by selecting the “Continue” button.
Step 4: Read through the End User License Agreement and click on the "Continue" button.
Step 5: Click on the "Agree" button to accept the license agreement and continue on with the installation.
Step 6: Select the installation type by selecting the “Install” button.
Note: There is the option to change the install location.
Step 7: Grant permission to install VEXcode V5 Blocks by entering your login credentials and clicking the "Install Software" button.
Step 8: Wait for the installer to finish installing the files.
Step 9: Click the "close" button to finish the installation of VEXcode V5 Blocks.
Step 10: MacOS will give you the option of moving the VEXcode V5 Blocks installer to the trash.
Click on the "Move to Trash" button to delete the VEXcode V5 Blocks installer. Otherwise, click "Keep" if you plan on using the installer again.
Step 11: Navigate to the Applications folder and double-click on the VEXcode V5 Blocks icon to launch the application.
Step 12: Begin working in VEXcode V5 Blocks.
