How to open a Project on a Chromebook - VEXcode V5 Blocks
Users can open a project in VEXcode V5 Blocks in different ways:
  • Opening an existing project using “Open” in the File menu
  • Opening an example project using “Open Examples” in File menu
Opening an Existing Project
Open an existing project by selecting “Open” from the File menu.
Then, use the ChromeOS interface to navigate and open your existing project.
Opening an Example Project
Open the example project chooser from the File menu.
Then, select an example project to open it.
Note: When opening a project, a prompt will appear asking to save if the current project has not been saved yet.
