How to Begin a New Project - VEXcode V5 Blocks
A new project opens any time you start VEXcode V5 Blocks. But, you can also open a new project after VEXcode V5 Blocks has already started.
Open the File menu and select “New” to open a new project.
Note: When starting a new project, a prompt will appear asking you to save if the current project has not been saved yet.
