How to Open a Project on iPad
Users can open a project in VEXcode IQ Blocks in different ways:
  • Opening an existing project using “Open” in the File menu
  • Opening an example project using “Open Examples” in File menu
Opening an Existing Project
Open an existing project by selecting “Open” from the File menu.
Then, use iPad interface to navigate and open your existing project.
Opening an Example
Open the example project chooser from the File menu.
Then, select an example project to open it.
  • There are filters by block categories at the top of the window to make selecting a project easier.
Note: When opening a project, a prompt will appear asking to save if the current project has not been saved yet.
