How to Run a User Program through the V5 Controller
Step 1: Make sure that your V5 Controller is on and linked to the V5 Robot
  • The V5 Controller should be powered on and connected to the V5 Robot.
  • For help in connecting the robot to the controller, go to this page about pairing a V5 Controller to the V5 Robot Brain.
Step 2: Move the highlight over the Programs icon and press the A button
  • Use the arrow buttons on the V5 Controller to move the dark highlight over the Programs icon.
  • Then press either the down-arrow button or the A button to select Programs.
Step 3: Choose the saved program
  • Use the arrow buttons to move the dark highlight over the icon of the intended program.
Step 4: Run the program
  • Press the A button to select Run.
Step 5: Use the program's running screen
  • Use this screen while the program is running to monitor the program's runtime and the battery's charge.
NOTE: To stop the program, hold the controller's Power button until it returns to the Home screen.
Still need help? Contact Us Contact Us
