How to Change the Language on the V5 Controller
Step 1: Make sure that your V5 Controller is on.
  • Power on your V5 Controller.
Step 2: Highlight the Settings icon and select it.
  • Use the arrow buttons to move the highlight over the Settings icon.
  • Press the A or down arrow button to select Settings.
Step 3: Make sure the Language option is highlighted and then press the A button.
  • Use the arrow buttons to move up or down to highlight the Language option in the Settings menu.
  • Press the A button to select Language.
Step 4: Highlight the language you want and press the A button.
  • Use the arrow buttons to move up or down to highlight the language you want.
  • Press the A button to select it.
  • This image shows that English is the third language listed in the menu.
