How to Manage Notes in a Project - VEXcode V5 Blocks
Here are some basic ways to manage notes in projects:
  • Adding a note to a project
  • Moving notes around
  • Deleting notes
  • Duplicating notes
Adding a Note to a Project
Right-click or long-press anywhere in the programming area and select Add Note.
Then, type any text, numbers, or symbols into the note.
  • Press the “Enter” or “Return” key to write a multi-line note.
  • Click anywhere in the programming area when the note is complete.
Moving Notes Around
You can move a note on a block by selecting the top margin and dragging it around.
You can move a note in a project anywhere by dragging it around.
Deleting Notes
You can delete any note by selecting the “X” located at the top right of the note.
Note: Deleting a block that has a note attached to it will also delete the note.
Duplicating Notes
You can duplicate a project note by right-clicking or long-pressing on it and selecting Duplicate.
