How to Mount the V5 Robot Radio to the VEX EDR Clawbot
Step 1: Collect the parts you will need
  • Gather two Screws 8-32 x 0.500" and one Hex Key 3/32".
Step 2: Secure the V5 Robot Radio and wire it
  • Use the two screws to mount and secure the V5 Robot Radio to the top of the arm support.
  • Use a Smart Cable to connect the V5 Robot Radio to Port 21 on your V5 Robot Brain.
