How to Use the Context Menu - VEXcode IQ Blocks
Right-clicking or Long-pressing in VEXcode IQ Blocks leads to many options.
The following article will cover:
  • The Context Menu in the Programming area
    • Undo
    • Redo
    • Clean up Blocks
    • Collapse Blocks
    • Expand Blocks
    • Add Note
    • Delete Blocks
  • The Context Menu of Block(s):
    • Duplicate Blocks
    • Delete Blocks
Right-clicking or Long-pressing in the Programming area in VEXcode IQ Blocks leads to the following options:
  • Undo: will reverse the most recent action.
For example, in the following project, the turn for block was deleted. Selecting “Undo” reverses that action.
  • Redo: will reverse the “Undo.”
  • In the last example, the turn for block was deleted and the “Undo” reversed that action. Selecting “Redo” will reverse the “Undo” so that the turn for block is deleted.
  • Clean up Blocks: organizes the blocks so that they are all in a vertical line.
  • Collapse Blocks: condenses the blocks to a read-only version.
    Note: blocks within C blocks will be collapsed within the C blocks.
  • Expand Blocks: expands the condensed blocks that were in a read-only form to their original expanded format.
  • Add Note: notes can be added to the programming area.
    For more information about notes, view the article How to Manage Notes in a Project - VEXcode IQ Blocks.
  • Delete Blocks: all of the blocks in the Programming area can be deleted at once.
  • For more information about deleting blocks, view the article How to Delete Blocks - VEXcode IQ Blocks.
    Right-clicking or Long-pressing on a block in VEXcode IQ Blocks leads to the following options:
    • Duplicate Blocks: this action will make an exact copy of the blocks selected.
    • Delete Blocks: individual or groups of blocks can be deleted.
