Installing VEXcode with MSI Installers
Note: If using a remote deployment system such as SCCM you may need to install the Driver Signing Certificate before running the driver installer. The Driver Signing Certificate can be found at this link.
VEXcode V5 Text
1. Install the VS 2013 Redistributable here:
http://download.microsoft.com/download/2/E/6/2E61CFA4-993B-4DD4-91DA-3737CD5CD6E3/vcredist_x86.exe
2. Install the VS 2017 Redistributable here:
https://download.visualstudio.microsoft.com/download/pr/e9e1e87c-5bba-49fa-8bad-e00f0527f9bc/8e641901c2257dda7f0d3fd26541e07a/vc_redist.x86.exe
3. Install VEXcode V5 Text with the MSI Installer found here:
https://www.vexrobotics.com/vexcode-download
4. Once all three are installed, run:
C:\Program Files (x86)\VEX Robotics\V5Drivers\Console Driver Installer.exe
as an administrator with elevated permissions.
VEXcode V5 Blocks
3. Install VEXcode V5 Blocks with the MSI Installer found here:
VEXcode IQ Blocks
2. Install  VEXcode IQ Blocks with the MSI Installer found here:
4. Once both are installed, run:
