How to Open an Existing Program in VCS (Upon Launching VCS)
Step 1: While VCS is open, select a programming language and click browse
Step 2: Select a file
For Mac:
  • Select the file that you want to open.
    • If it is not saved inside of your Downloads folder (like in the image above), then you will need to select a different folder to find the file.
  • Click Open.
For Windows PC:
    • If it is not saved inside of your Projects folder on your Desktop (like in the image above), then you will need to select a different folder to find the file.
  • Click Open.
