VCS Example Program - Modkit - V5 Clawbot - Driving Forward and Backward
Get more with VEXcode
We recommend you transition to our new software. VEXcode has both block-based and text-based options, that work on Chromebooks, iPads, Android tablets, Windows and Macs. Visit code.vex.com for more details on how to download VEXcode.
VEX Coding studio has been discontinued and is no longer available for download. Already downloaded? The program will continue to function but will no longer be supported.
Users who transition to VEXcode can migrate their C++/C++ Pro projects to VEXcode Text by following this article.
This example program shows how to program the V5 Clawbot to move forward and backward using Modkit.
BasicForwardBackward.vex
Configuration
  • A V5 Smart Motor, on Port 1, named LeftMotor.
  • A V5 Smart Motor, on Port 10, named RightMotor and set to Reversed.
Program
How it works
First, the when (STARTED) block tells the robot to run this code when the program starts. A number variable, howMany is declared and assigned to 1.
Then, the left motor is set to start rotating. Since startRotateFor is used, the motor will begin rotating and the program will continue immediately.
Next, the right motor is set to rotate as well. Since rotateFor is used, the program will not continue until the motor completes its rotation.
Then, when the right motor has finished rotating, the program will pause for 1 second.
Finally, the howMany variable is set to -2, and the motor rotation blocks are repeated. Since a negative number is given to the motors, they will spin in the opposite direction this time.
